Power Button logo Blinking Red 2 Times only
When I turn on the laptop, the power is on but then it only flashes red 2 times and then it's gone and it repeat few times then it's off. Anyone know how to fix this?
Es esta una buena pregunta?
If it is a 2:2 blink error code that this means there's a System board problem - BIOS and ROM failure
This could be due to corrupted BIOS software.
Try a power refresh and check if that resolves the problem.
Here's the procedure:
Here's the service manual for the laptop that will help. Go to p.29 and then p.25 to view the procedure to remove the main battery and the RTC coin cell battery. You don't have to remove the main battery, just disconnect it.
When the RTC battery is disconnected, check its voltage. If it is <2.5V DC (or if it is >5 years old) replace it. Search online for cmos battery for DELL Alienware 13 R3 to find suppliers that suit you best.
If it does turn on OK then there may be a message that the date and time are incorrect. This is normal as a power refresh resets the BIOS back to its factory default state. Once the date and time have been corrected, the message won't appear the next time that the laptop is started.
Also any user definable BIOS settings that were changed by you, to suit whatever operating requirement you had, will have to be changed back again as well.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 25
Ultimos 30 días: 98
Todo El Tiempo: 321
