What precision screwdriver bit set to purchase to remove hard drive
want to remove hard drive. what precision screwdriver set should i purchase for the job
Es esta una buena pregunta?
Here's the ifixit PowerBook G4 Aluminum 15" 1.5-1.67 GHz Hard Drive Replacement guide that will help.
In the What you need → Parts box click on Show more to view the tools necessary to do the task
Fue útil esta respuesta?
Sadly this system uses a PATA drive interface so you will need another Mac system which supports PATA (IDE) natively or via a PATA to SATA adapter to retrieve the data on the drive.
thank you for your help. i was able to remove the hard drive.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 59
