Laptop not turning on
when click on power ON button then on keyboard only caps lock button light blinking continuously.
Es esta una buena pregunta?
Hi @sujit72617
What colour is the Caps Lock button and how many times does it blink?
Usually it is not a continuous blink but a pattern of blinks that are repeated after a small pause between each set.
The blinks are an error code that tells you what's wrong.
Here's a link that will help you to find out what the problem may be.
Click on the Identify the Notebook Light or Beep code link on the page.
Here's the hardware maintenance manual for the laptop that will help if you need to open the laptop and check/replace any components.
Fue útil esta respuesta?
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 32
Todo El Tiempo: 169
