Saltar al contenido principal
Lanzado en marzo de 2010
Preguntas 2 Ver todo
How can I tell if the problem is the fuse?
How can I tell if the problem is the fuse? Is there “a tell” that the problem is the motor or circuit board before searching for fuses? For the 1st micro second it moves an inch like it’s getting power.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Use a multimeter and test it for continuity:
Vornado Duo Fuse Replacement
Fue útil esta respuesta?
Puntuación 0
@djlaine17 you can't, until you test it with a multimeter. If you have not done this before, check something like [https://www.youtube.com/watch?v=Kxl-IjEl... |this video for the How-To.
This "micro second it moves an inch" leads me to believe that it is not your fuse. When the fuse is "blown" there is not power going through the circuit. None. That means you would not get ANY movement. The issue you are describing sounds like either a capacitor issue or a motor driver issue. Once you checked the fuse to verify, check the circuit board Vornado Duo Circuit Board Replacement for any obviously damaged looking component or burned traces etc. Post some pictures of what you find/see with your question. That way we can see what you see. Also, make sure that tell us the exact make and model of your fan
Agregar imágenes a una pregunta existente
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Vornado Duo Circuit Board
Guía
Dificultad:
Moderado
9 - 10 minutes
Puntuación 0
Añadir tu respuesta
Djlaine17 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 170
