Why is camera not turn ON
Camera not turning on
Es esta una buena pregunta?
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100 LCD Replacement to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
Fue útil esta respuesta?
Ultimas 24 horas: 5
Ultimos 7 días: 11
Ultimos 30 días: 38
Todo El Tiempo: 211
4 comentarios
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
- de jayeff
Yes, I already checked it
- de Priyeshcamera
Start problem not running
- de Binod Saw
Camera is 1year old please recover
- de Display is on but don't work
