Saltar al contenido principal
Sony Cyber-shot DSC-S2100 LCD Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: paso 1, imagen 3 de 3
    • The broken LCD is immediately visible when the camera is turned on.
    • Remove the batteries and, if so equipped, the memory card.
    • Remove the three Philips screws from the bottom of the camera with a Phillips #00 Screwdriver.
  2. Sony Cyber-shot DSC-S2100 LCD Replacement: paso 2, imagen 1 de 3 Sony Cyber-shot DSC-S2100 LCD Replacement: paso 2, imagen 2 de 3 Sony Cyber-shot DSC-S2100 LCD Replacement: paso 2, imagen 3 de 3
    • Remove the two Philips screws from the right side of the camera.
    • Remove the two Philips screws from the left side of the camera.
    • Split the housing by either using a plastic opening tool, or your finger nails. No excessive force is necessary. For ease of accomplishment, start at the battery compartment.
  3. Sony Cyber-shot DSC-S2100 LCD Replacement: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-S2100 LCD Replacement: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-S2100 LCD Replacement: paso 3, imagen 3 de 3
    • Once the rear case has been removed, the LCD and frame are easily identified.
    • Fold the LCD to the right, away from the frame.
    • Do not try to remove the LCD yet since the ribbon cable is still connected.
    • Remove the three Philips screws from the LCD frame.
  4. Sony Cyber-shot DSC-S2100 LCD Replacement: paso 4, imagen 1 de 3 Sony Cyber-shot DSC-S2100 LCD Replacement: paso 4, imagen 2 de 3 Sony Cyber-shot DSC-S2100 LCD Replacement: paso 4, imagen 3 de 3
    • When the LCD frame is removed, the ribbon cable becomes clearly visible.
    • Flip the LCD to its left side. Open the clip of the connector by moving the black lock to the right.
    • Remove the LCD
  5. Sony Cyber-shot DSC-S2100 LCD Replacement: paso 5, imagen 1 de 1
    • Ensure the screen displayed greets you, once you reassembled your camera
Conclusión
4 personas más completaron esta guía.
oldturkey03
Miembro Desde 09/29/10
785,013 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
574 Guías creadas
2 comentarios
你在哪里?把相机给你帮我挨可以吗
Jeanne - Contestar
请问你是在多伦多附近吗?
Jeanne - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 45
Todo El Tiempo: 2,497
