Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Presentado en 2017, fue el modelo insignia de la empresa, identificado con el nombre en clave Sagit. Cuenta con el procesador Snapdragon 835, acompañado de 6 GB de RAM y una GPU Adreno 540
How to replace screen
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
3 Respuestas
Respuesta Más Útil
@singgsirya iFixit does not yet a guide for this. Use the one from here to replace your screen. Since we do not know where you are located, I suggest an online search for a replacement screen within your part of the world.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Fue útil esta respuesta?
Puntuación 1
Display change
And power bottom change
Puntuación 0
1 comentario:
I'm going with the assumption you meant "button" rather than "bottom", because the phrase "power bottom" has a whole different meaning in this country than what you probably intended.
If you need to change the electrical part of the button including the click dome, use this guide.
https://www.nadiemellamagallina.com/en/m...
If you want to replace the physical part of the button that you press, use this one.
And see @oldturkey03's answer for the guide to replace the screen.
- de
Mobile no the wrking
Puntuación 0
1 comentario:
Mobile display no werke
- de
Añadir tu respuesta
Singg Sirya estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 37
Todo El Tiempo: 1,279
