The more sane option is to only connect it to WiFi for setup, and as needed for book downloads. Once you are done, turn the WiFi off. That said if you wanted to do it offline you can usually purchase things like books and music on a computer with iTunes (Windows), but for MacOS you need to use the Books app and use WiFi to download that way; there's no total workaround on a Mac. iPads and iPhones are also very tightly integrated to the point of something as silly as a cellular radio failure killing the ENTIRE PHONE (See: A1660 iPhone 7 due to the bad Intel GSM radio; this was an AT&T/T-Mobile locked variant that was so bad about dying Apple had to issue a REP for it). Removing the WiFi chip may very well kill it the same way if you ever have to restore it, as it's probably tied to the activation process.
The reason this will be better for you is resale: It won't kill the tablet, and if say I found out you disabled the WiFi and re-enabled it physically, I would look at another iPad used even if you begged me to give it a chance at a discount; having to hope a reversed modification does not cause me future grief kills the deal unless I am stripping it for parts except the motherboard. The main concern I'd have is later activation issues I cannot repair (and Apple refusing to service the iPad since you can't just get a motherboard due to the excess serialization), so that would be reason enough to pass on that unit. I don't mind things like 3rd party SSDs and engraving (as long as the removal is subtle and the price accounts for the wear and tear I will put on the device removing that so people do not accuse me of theft) but the line is drawn hard in the sand at modifications like this for me.
You could always look into an MDM provider like JAMF as well and restrict it to the point it is only usable on WiFi for those things only and block Safari (but allow updates to work if you block everything else but those things), but this is probably impractical for an individual due to cost or inexperience. For enterprises, this is viable because they will often manage a bunch of devices this way and have "groups", if you will; some are used for X, some for Y, and others get locked down hard like ones used for self-checkout or devices used to show a specific product. If the MDM method will not work (I don't recommend it unless you know how to release the MDM from the iPad from the console >_<), you can lock it down with ScreenTime as well.
