The screws used in the Nintendo 64 Controller vary in size depending on their location within the controller. Here are some general measurements for the screws commonly found in the N64 Controller:
- Exterior screws: M3 x 8mm (machine screw)
- Pak port screws: M2 x 5mm (machine screw)
- Joystick screws: M1.6 x 4mm (machine screw)
- Screw for the joystick spring: M1.4 x 3mm (machine screw)
Please note that these measurements are approximate and may vary slightly depending on the specific model and version of the controller. It is always best to double-check the measurements with a caliper or ruler before purchasing replacement screws.
I apologize for the error in my previous response. Here are the correct measurements for the screws commonly found in the N64 Controller:
- Exterior screws: M2.6 x 10mm (machine screw) These screws are used on the exterior of the controller to hold the two halves of the controller together. They are machine screws with a diameter of 2.6mm and a length of 10mm.
- Pak port screws: M2 x 6mm (machine screw) These screws are used to hold the Pak port in place on the bottom of the controller. They are machine screws with a diameter of 2mm and a length of 6mm.
- Joystick screws: M1.6 x 6mm (machine screw) These screws are used to hold the joystick mechanism in place on the inside of the controller. They are machine screws with a diameter of 1.6mm and a length of 6mm.
- Screw for the joystick spring: M1.4 x 4mm (machine screw) This screw is used to hold the spring in place on the joystick mechanism. It is a machine screw with a diameter of 1.4mm and a length of 4mm.
Again, please note that these measurements are approximate and may vary slightly depending on the specific model and version of the controller. It is always best to double-check the measurements with a caliper or ruler before purchasing replacement screws to ensure compatibility with your controller
