Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Pantalla LCD de 20", 23" y 30" presentada en 2004 descontinuada en 2010.
Adding a Fuse to Protect Display
The Apple power supply finally bit the dust, it was used on my 30" Cinema Display. I have purchased one of the $20 240 Watt, 10 Amp power supplies to replace it. I would feel much more comfortable using this inexpensive PSU if I could add protection between the display and the power supply. I welcome any advice on how to add a fuse with the goal of not destroying the display should the power supply go haywire.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
@charles218 lets see what the end connectors look like. You can always add a 25 V 8 A inline fast-blow fuse.
Fue útil esta respuesta?
Puntuación 0
6 comentarios:
I am planning on removing the connector from the dead Apple power supply and using it with the new power supply, this way I don't have to cut the display cable. It looks like the fuse would need to go between the recycled connector and the power supply tap.
- de
@charles218 yup. Right one the power lead.
- de
Is it important that the fuse holders wire be the same gauge or close to the same gauge as the connection wire?
- de
@charles218 not on that length. You'll be fine with slightly smaller/bigger leads.
- de
Old Turkey, you have been very helpful, thanks! I searched for the past half hour or so for 25 V - 8 Amps without success, nothing comes close, so if you or anyone has any leads on where I can find it, please let me know.
- de
Mostrar 1 comentario más
Añadir tu respuesta
Charles Larkins estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 26
Todo El Tiempo: 447
