Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Altavoz Bluetooth portátil con 14 horas de reproducción. Resistente al agua con certificación IPX7. Exterior de goma a prueba de golpes. Batería externa de 1800 mAh. Lanzado en 2015.
Device won't charge
The device won't charge anymore. I've tried different cables that work fine with other devices and used to work fine with this. I've tried cleaning the port. I've tried the reset button.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Becky Dale sounds like you have come to the point of having to change the battery. This device is a bit of a bear to work on. You will have to remove the motherboard since the battery is located beneath it. Use this guide Sustitución de la placa madre del Braven BRV-1s to do so. I suggest that you take plenty of pictures a you work on it. It will help you for the reassembly and you can also post pictures with your QUESTION if you get stuck and need further help. Even so it's a chore to work on it, it is definitely the right thing to do. We are here if you need help to get it going again. Repair is War on Entropy.
Agregar imágenes a una pregunta existente
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Braven BRV-1s placa madre
Guía
Dificultad:
Muy difícil
1 - 2 hours
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
I can't seem to get the motherboard out (I've taken out the screws and am doing what the motherboard replacement suggests but I don't want to unsolder if I'm not replacing the motherboard). I'm also wondering if the battery is built into the motherboard in this model. Here's a link to a photo: https://photos.app.goo.gl/HjopnBbNsVCPRK....
- de
@Becky Dale it sure looks like its underneath that motherboard. The black and red wire seem to be leading to it. Looks like they used some glue or sealant to keep the board in place as well. You will have to remove the Philips screw to get the top board off. If the cables get tight when you try to move it, you know you will have to desolder those. As for the glue/sealant, keep a heat source handy. Either a good hair dryer, or a heating gun (low settings don't want to melt the case) should soften the glue.
- de
Añadir tu respuesta
Becky Dale estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 409
