Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1418 / finales de 2012 / procesador Core i5 de 2.7 y 2.9 GHz o Core i7 de 3.1 GHz
Can I add a ssd hard drive when it seems to have never had a hd?
To begin, I’m mechanical but not incredibly computer-savvy.
I have an i5 late 2012 emc2544 21.5” iMac. It has been running fine but I have run out of room. It said it has a 64gb hard drive.
I bought a 1tb ssd upgrade kit from ifixit and opened it up tonight. I was surprised to see no drive in the slot. I’m unfamiliar with all of the terms used and just trying to figure out if I can add this drive to my system as an internal hard drive or if I have to put it into an external case and just use it like that.
I’ve seen things that make me think I can get cables and add it but I’m just not sure.
Update (02/02/2023)
There is no hard drive in the little compartment.
Imagen
I hope this picture comes through
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Can you take a picture of your current drive posting it here for us to see and point us to what you bought so we have a better idea.
Update (02/06/2023)
OK, I think I get it where’s the drive?? Well hidden!
Your system came with a blade SSD which is mounted on the backside of the logic board. Review this guide Reemplazo del SSD del iMac Intel 21.5" EMC 2544
So I would leave it be and just add in a second drive following this guide Reemplazo del disco duro del iMac Intel 21.5" EMC 2544. You will need to get these two cables Data cable and Power cable
Update (02/07/2023)
@jfryjfry - Here’s the drive connectors on the back side which I circled.
Imagen
Imagen de iMac Intel 21.5" EMC 2544 Disco duro
Guía
Dificultad:
Moderado
25 minutes - 1 hour
Imagen de iMac Intel 21.5" EMC 2544 SSD
Guía
Dificultad:
Moderado
2 hours
Fue útil esta respuesta?
Puntuación 4
3 comentarios:
Added a pic to the initial post. Thanks for taking a look.
I put it back together to check what it says it has and it has 250gb flash storage. So I’m guessing it never had an actual hard drive. Can I add one???
- de
I’m cautiously optimistic… I see no place to plug the two cables onto the board and the installation procedure obviously shows them already in position because that one came with them.
I haven’t taken the board out and cannot see underneath it but I can’t imagine there are two open slots. Or should there be??
- de
Parts ordered! I’ll update when I pull it apart (again!)
- de
Añadir tu respuesta
Jeremy fry estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 271
