Saltar al contenido principal
Cursor stuck in the upper left corner
I just replaced the logic board and optical drive and when I boot up the mouse pad does not work. What should I check 1st?
Update
The built in track pad is not working. I am checking the connection now. I was hoping to find out which connection is the likely problem.
thanks for the help
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
Solución Elegida
Do you mean you're running a USB mouse or the in-built trackpad on the keyboard area? If it's USB the check ports externally for dirt/bent pins and for solder crack internally. If it's the trackpad and you had no previous prioblems then you should recheck your connection there.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
Reseat the keyboard connector making sure you haven't bent over any pins on the connector: Reemplazo de teclado en PowerBook G4 Aluminum 12" 1-1.5 GHz
- de
The 4 pins are straight and connector seems fine. Yet no track pad working yet.
USB mouse does work.
Puntuación 0
Añadir tu respuesta
John SS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 703
