Saltar al contenido principal
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
Preguntas 20 Ver todo
Dell XPS 13 laptop will not power on
When I press the power button the indicator momentarily comes on then goes off. I performed the power and rtc reset several times with no success. My next move will be to remove the back cover and pull the integrated battery connection.
If this doesn't work what will be the next steps to isolate the problem? I am debating whether to risk purchasing a replacement motherboard or play it safe and buy a new laptop?
Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
So yes unplug charger and disconnect the battery connector,
Plug in just the charger and see if it powers up.
  • If yes then time to replace battery (how old is it?).
  • If no then remove the RAM memory, HDD/SSD hard drive and any cards like WIFI.
If it powers up now then the motherboard is probably good. Add one component at a time until it doesn't power up. That is the defective component.
Tell us how it goes.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Ray Dragowski estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 25
Todo El Tiempo: 919
