Saltar al contenido principal
Guía de reparación e información para los controles Joy-Con de Nintendo Switch
Preguntas 125 Ver todo
trying to replace case on nintendo switch joy cons
so long story short im trying to replace the casing on a set of joy cons and the casing that i bought... doesn't have a instruction manual in the box ._.
the rear casing won't come off after unscrewing all the screws also
help???
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
https://www.youtube.com/watch?v=ymBbKWzL...
Fue útil esta respuesta?
Puntuación 1
Hello. I believe that the ifixit guide for joy cons might help. They explain how to take them apart and disassemble it.
Just use the part where they talk about joycons
Teardown de Nintendo Switch
Puntuación 1
Did you remove the rails before you took out the screws? The back plastic should come off relatively easily.
Be sure to open it like a book with the part that slides into the switch as the books spine.
Check out this guide for how to get into the case.
Puntuación 1
Añadir tu respuesta
timtom7777 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 35
