Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
El Meeting Owl Pro es un sistema de cámara, micrófono y altavoces de 360 grados creado para llamadas de conferencia colaborativas.
How to replace camera
I have an Owl Meeting Pro that fell off the table and now the camera is broken. The top dome appears undamaged but something in it is broken. The camera picture is mostly blurred/black. Its this something that can be repaired?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 10
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Caroline. I know its been a while and my answer will probably not be helpful to you at this point. When the Owl webcam falls off (because most of its weight is in the top, so it is easy to tumble), it often breaks inside the lens. The fisheye lens is built like a cone or a mushroom and it will break where the lens comes inside the cone to each the camera sensor.
That being said, there is no replacement lens available (well, at least not documented). The only workaround is to find a donor webcam from which you will get the lens (and the camera sensor if needed) and "transplant" it to the webcam you are trying to salvage.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
caroline work estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 13
Ultimos 30 días: 70
Todo El Tiempo: 1,880
