Saltar al contenido principal
The backlight is not turning on when I use it.
My friend found a green one of these and when we tried to use it the backlight is not turning on. I dont know if it is because the screen light is burnt out, or the fact that it has been sitting in a kitchen drawer for 6 years.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
jaj there are two distinct possibilities. One, it is a failure on the backlight of the screen, which would be repaired by a screen replacement, Reemplazo de la pantalla del iPod Nano 5ª Generación
Two, it is a failure of the circuit that powers the screen's backlight on the main circuit board. There are no schematics for this iPod (or any other iPod really). You could check for failed components and hope it's the backlight coil. Or you could replace the logic board (as above PITA) Reemplazo del conjunto de la placa lógica del iPod Nano 5ª Generación The failed backlight is actually a pretty common issue with the 5th Gen Nano.
Imagen de iPod Nano 5th Generation Conjunto de la Placa Lógica
Guía
Dificultad:
Difícil
Imagen de iPod Nano 5th Generation Pantalla
Guía
Dificultad:
Difícil
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Well the iPod works fine besides the screen, but there is some light green spots on the back. i also had the thought that it may be water damaged cause of the spots, and the fact that it was in a kitchen drawer near the sink area.
But thank you for helping.
- de
I think you need to replace the LCD as that could be causing the problem
iPod nano (5th Gen) Color Display
Imagen de Replace a malfunctioning or dim LCD display compatible with the fifth generation iPod nano.
Producto
$12.99
Puntuación 1
Añadir tu respuesta
jaj estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 116
