Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Maxima fue rediseñado para el año modelo 2009 y debutó en el Salón Internacional del Automóvil de Nueva York de 2008.
OBD giving 1778 engine light code
My car is accelerating slow after coming to stops. The engine light is giving me a 1778 code and after some research I learned that I needed to replace the stepper motor. After replacing the stepper my issues were still there. I tried replacing the Mass air flow sensor and the problem is still there as well. What else could I try?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Try searching for Nissan Maxima forums. Owners share info freely and may help you. If you have a cvt, this may be a known problem.
- de
Agregar un comentario
1 Respuesta
After installing the parts you have to reset the error codes. You can wait for few miles to detect the issue has been solved and the error code will gone. It is also possible you have some more parts has fault. Please contact any expert technician locally to examine the issue.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Quincy Williams estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 350
