Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
No interior lights and water/ice not dispensing
All 3 lights are out in the fridge/freezer and water/ice stopped dispensing. I just assumed the lights burnt out but when the water stopped dispensing and ice was no longer producing I looked into the issue a bit further.
I originally assumed the water line was frozen. I took everything out and let the fridge sit, unplugged, for a day. When I turned it back on the lights were in and water petered out, but lasted maybe 2 minutes. I did that for 2 or 3 more tries for it to only last a second or so.
I read online refrigerators can be reset by pressing unlock and light simultaneously, but that trick didn't work either. Any help would he appreciated.
The model number for our fridge is WRS322FDAM04.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
Water dispensing and lighting may be a control board issue. Ice making depends on freezing temperatures around 0F before ice making can operate.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @youngd2411
It may be a faulty light switch i.e. door switch, that is affecting both the lights and the dispensing of the water/ice.
Looking at the tech sheet for the refrigerator, there is a light interlock changeover switch through which both the lights and the dispenser circuits go - see image below.
Usually you can't dispense with a door open and the lights require the door to be open to work. Might be worth checking if it is OK, corroded, loose etc
Imagen
(click on image to enlarge)
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Danny Young-Uhrich estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 15
Ultimos 30 días: 52
Todo El Tiempo: 5,915
