Saltar al contenido principal
Temperature Guage remain at rest on dashboard
Good day, my car is 2002 Honda accord, the temperature Guage remain at rest, not even climb to cool, I’ve changed the sensor but yet no response. Please I need possible solution.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi,
It may be either a faulty gauge or faulty wiring from the sensor to the ECM/PCM control unit, a problem in the control unit or faulty wiring from the control unit to the gauge.
Here's the wiring for the coolant temperature gauge from the 1998-2002 Honda Accord service manual that may help.
Note* The ECM/PCM unit is under the dash behind the steering wheel and not "in" the steering wheel as it might appear to be in the diagram
(click on images to enlarge)
There is no wiring diagram or schematic for the ECM/PCM so hopefully the wire colour of the wire at the sender unit is the same at the control unit connector from the left side engine harness cable.
Fue útil esta respuesta?
Puntuación 1
Change the ECM/PCM control unit (brain box) and thank me later
Puntuación 0
1 comentario:
That would be an expensive fix, especially if it's just a broken wire on the temperature sender. I'd do a lot more diagnosis before resorting to that as a fix.
- de
Añadir tu respuesta
Olayinka Adedoyin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 48
Todo El Tiempo: 356
