Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Hp Notebook 15-ba018ds es un portátil con pantalla táctil equipado con el sistema operativo Windows 10. Mide 16 x 10 x 3 pulgadas cuando está cerrado y pesa 4.83 libras.
Why are these voltage differences?
Hello everyone.
Please, I would like your help in order to help me understand what and why are these small voltage differences on laptop batteries when going for new buy for replacement.
laptop model is:HP Pavilion 15db1027nv
HP original battery is: HT03XL (or REPLACE WITH HP SPARE L11119-855)
On original battery also:
11.55V
41.7Wh
3470mAh
Just exactly like here:
https://www.amazon.com/Compatible-L11421...
But, on many selling sites, the elements (Volts, Wh, mAh) differ a little, just like here:
https://www.aliexpress.com/item/10050041...
Here, Voltage is not 11.55 but 11.40.
a. On replacement, shouldn't voltage be EXACTLY the same? If second battery, with 11.40V is bought and installed, what are the coincidences? Could it cause any damages?
b. What and why batteries are produced even with this small differences?
Thank you for your time!
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
@johnyb98 shouldn't voltage be EXACTLY the same? No. The voltage listed is the nominal voltage and does not take the typical end-of-discharge and max charge voltage and other variable like ambient temperature etc. into consideration. That is why variations are absolutely normal. You do not know the state of the new battery vs. the old battery. Could it cause any damages? Not it it is within the parameter of your device (don't use a 12V battery on a 5V device;-). remember that even batteries are now smart devices. There are circuits that control over and under voltage (within reason) and the 2% difference in your battery most certainly will not do any harm to your system. Remember, you do not know the charge state of your battery. You are good to use that battery without any sequalae to your computer.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you very much for your answer and these precious technical information!! You totally helped and covered on my questions.
- de
Añadir tu respuesta
John Eidert estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 324
