Broken jack connector after falling
hello, I am looking for the reference of the jack connector to replace it, can you help me?
FYI all pin of the connector broke after a 20cm fall with the jack plugged in
Es esta una buena pregunta?
Hi there,
as you might have noticed we just made a bunch of Steam Deck parts available in our stores.
We definitely have a guide for this problem (but not that specific spare part, yet). So make sure to check back for more parts that might join the current selection (though I can’t promise anything since I don’t know). Hopefully, you can manage until this part is available.
Meanwhile:
As I understand it the actual headphone port on that audio board is broken, which means you might try and fix it by soldering as long as the solder joints on the board weren’t damaged.
If it’s "just" the headphone jack itself (TRRS plug from your headphone) that got stuck in the port you might be able to get it out using this nifty tool.
Cheers and game on
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 531
1 comentario
I found the reference for the jack connector only if this can help someone else :
brand : WNRE
- de Wallace Breen
