Saltar al contenido principal
Un PC de escritorio construido a partir de piezas de bricolaje listas para usar, en lugar de uno prefabricado de un fabricante importante. Estos también pueden ser construidos por un IS utilizando piezas listas para usar.
Preguntas 20 Ver todo
Won’t turn on
Put in a gpu and power supply and my pc wont turn on
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
5 comentarios:
Hi,
What is the make and model number of the motherboard?
Was it working OK before you plugged in the GPU card and PSU or is it a new setup?
if new what is the make and model number of the GPU card and the PSU?
- de
Is it newly build or was wroking well before after changing gpu and now this problem came up?
- de
@jashan0 it was working well before a I added my new gpu and psu
- de
@Keegan Isma
What happens if you remove the GPU card and the PSU and restore it to what it was before, does it work OK again then?
Providing the motherboard, gpu card and PSU make and model information will help us to help you.
- de
Return the computer to it's original working condition, Then replace 1 unit at a time and test it each time to isolate the faulty part. Please contact us again if you need more ideas /help with this issue!
- de
Agregar un comentario
1 Respuesta
did you reseat the main connector to the board? check the power switch on the header and make sure its still plugged in.... try jumping the power pins? reseat the power connector on the GPU? is this a modular or semi modular power supply? is the GPU seated all the way into the connection on the board? is the power supply rated for the GPU and all other components for your computer.... 100's of what ifs....
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Keegan Isma estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 83
