Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
7.2 megapíxeles, zoom óptico 3x, pantalla LCD de 2.5 pulgadas, lanzado en agosto de 2006
Camera Shows "Lens Error"
The camera powers on, and briefly shows an image on the LCD display. Then eventually it gives a "Lens Error" message.
Has anybody gotten this error before? Know how to fix it, I'm thinking that since the camera shows an image on the LCD, it may be a software rather than hardware problem.
Es esta una buena pregunta?
Puntuación -1
3 comentarios
what error no. does it give?
- de
pollytintop, I think it's one of those cameras that just says "Lens Error". Usual cause is sand grid and grime in the rings, a dislodged lens, or faulty lens motor. :-)
- de
Any way to fix it?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
If the lens does not extend/retract properly, then you most likely have something stuck in the zoom gears. If the lens extends but you hear a high pitched buzzing noise, it is the focus motor that is the gears are out or your have debris it it. I would start by reading these tips and see what you get. Also take a quick look at this video to see what you might be up against :-) hope this helps, good luck
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Danny Arenales estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 13,643
