Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Fridge door Hinge replacement parts?
Imagen
Imagen
Imagen
Whirlpool WRF560SEYM00
Could anyone tell me what parts I need to replace? I thought the door cam but there’s nothing for it to stay in place inside the door.. my daughter was having a fit & swung the door open.. thanks in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
3 comentarios
@pinkdiamond Did you ever find a solution to this? My fridge door is broken in the same way and I can't find a replacement part.
- de
I ended up getting JB weld putty and put it in the hole with a new bushing. has been working flawlessly ever since.
- de
Thanks so much, I'm going to give that a try!
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi @pinkdiamond ,
Looks like the hinge centre pin assembly part #14 cabinet parts is broken.
If you determine that is it broken, then there are other parts suppliers online that may suit you better. Just search for WRF560SEYM00 parts to get results
Fue útil esta respuesta?
Puntuación 1
If you have your owner’s papers, there should be a phone and online Whirlpool site for support. There may be a parts diagram on paper or Whirlpool online to search for parts. Swinging the door without stopping it may have broken a plastic pin meant to serve as a hinge instead of a metal pin. Whirlpool parts diagrams can help pin point which parts to replace. If Whirlpool doesn’t supply parts then searching for repair and distributors of parts would be the next step. Last is calling in a Whirlpool service repairman.
Puntuación 0
Añadir tu respuesta
Marissa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 98
Todo El Tiempo: 4,301
