Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Procesador 1.5 Core Solo, 1.66 o 1.83 Core Duo, o 1.83 o 2 GHz Core 2 Duo. Esta guía cubre los primeros modelos de Mac mini con procesador Intel, desde principios de 2006 hasta mediados de 2007.
PRAM Battery Not Working
A Mac Mini I have wasn’t saving the date and time/wifi so I ordered a new PRAM battery. I put it in but the date and time/wifi still isn’t being saved. I flipped it around but the same issue occurred. I have pushed the metal fingers as close to the battery as I can, yet it still wiggles a little bit, so maybe that’s why? I tried it on another A1176 I have and the same problem.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
5 comentarios:
What is the batter markings?
It sounds like you either got the wrong one or its bad
- de
@danj I bought the ones that were in the guide
- de
@Jordan Baron - What is the batteries markings?
- de
@danj Energizer CR2032
- de
@Jordan Baron - Well, that's the correct battery, why I pressed was there is a thinner battery which is only 1.5v.
Your comment "yet it still wiggles a little bit" made me question if that was your issue. At this point your logic board socket maybe damaged as the battery is firmly held.
- de
Agregar un comentario
1 Respuesta
Before you return what sounds like a bad battery, open up the date and time preferences and make sure you have the “set date and time automatically” checked.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Jordan Baron estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 392
