Saltar al contenido principal
El Razer Naga Trinity es un mouse para juegos fabricado por Razer y con la tecnología de Razer Chroma. Este dispositivo viene con tres paneles laterales intercambiables y es compatible con computadoras Mac y Windows. Número de modelo RZ01-02410100-R3U1.
Preguntas 7 Ver todo
Where can I buy a replacement encoder wheel?
TL;DR: Previous owner asked me to look at it after it had issues with vertical scrolling, tried to fix it and does not want the mouse. This is a $100 mouse (new), so it’s at least worth trying to save.
When you try and use the mouse, the scroll wheel always scrolls down, rather then up; it’s essentially unusable right now since it’s always happening. I already tried cleaning the sensor with canned air, and the issue persists so I did make an attempt to save it for nothing. However, this one uses the LK-E5 (4 wire) wheel, yet I cannot find them on eBay; just the 3 wire :(.
Is there a source I can get 2-3 of the LK-E5 encoder wheel (ideally, with the Razer specific connector)? I tried to find one, and I cannot find one from a domestic seller or a one-off seller from China for the time being. The rest of the mouse is fine, but just the scroll wheel has an issue.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Hi @nick ,
Tongue-in-cheek answer ;-)
You could always become the source for these in the USA and contact this supplier and ask what the minimum quantity is. (500?, 250?)
Might take a while to recoup the cost (+ shipping) if the minimum is 1000 though.
Cheers
- de
Agregar un comentario
1 Respuesta
Hi Nick! these manufactures make it REALLY hard to buy component level replacement parts, as youve found out im sure.
i think your best bet would be trying to find a donor mouse to pull from
something like this
https://www.ebay.com/itm/Razer-Naga-Trin...
good luck !
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 307
