Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
The Ecovacs Deebot 900 is an autonomous robot that vacuums the floors of your home. This page includes repair guides and troubleshooting tips.
How to replace LDS (laser sensor)?
This seems to be one of the most common problems in this vaccum cleaners. Is there any tutorial on how to repair the LDS malfunction error? And where to find the replacement parts needed?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
error message Dlof laser component malfunction. What does this mean and how can I resolve this issue?
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
I didn’t realize it was a belt, I thought it was just an o-ring. I dismantled my R95 trying to find out why the LDS wasn’t rotating anymore and found the rubber o-ring/drive belt broken and slightly jammed into the rotating navigator which houses the lasers. It came out pretty easily. There is a repair place, ifixrobot.com/Ecovac but they never responded to me. It took a while and many trials but a friend has a machinists book of everything and he determined what size o-ring I needed for the drive belt based on the measurements of the broken o-ring and then found it on Amazon. It’s working well. I didn’t take any photos and feel awful for not doing so for others but the video link below does cover what I did although in a less direct manner. I will tackle the project again after I fix my Shark and post photos in sequence. In the meanwhile for the R95 DEEBOT and the LDS 002 navigator (presuming it might be used on other Deebot models), the belt is a 2-042/N7 70 Buna O-ring the size is 3-1/4”x3-3/8”x1/16” With any luck this link will still work when you need it.
https://www.amazon.com/dp/B01D0BD8KO?psc... https://www.amazon.com/dp/B01D0BD8KO?psc...
Fue útil esta respuesta?
Puntuación 1
jmbaroso take a look at https://www.youtube.com/watch?v=9StRbMPP... |this video) see if that helps. If so make sure that you create a manual for the rest of us https://www.ifixit.com/Guide/new
Puntuación 0
One guy on Amazon said he clears this error by removing the pet hair that might be stuck around the sensor on . I tried a similar solution and forecfully blew air all around the sensor. Cleared the error straight away.
Puntuación 0
The comun problem with this unit when LDS error appear is the belt that move the lazer motor is broken…,
Puntuación 0
1 comentario:
What do you use to replace broken belt, and where do you get it Thanks Joe
- de
Añadir tu respuesta
jmbarroso estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 87
Todo El Tiempo: 15,170
