Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La eMachines ET1831-05 es un sistema de escritorio económico fabricado por eMachines.
Power LED doesn't light up
IHave a desktop emachines model 1831
The Power LED Doesn’t light up?
Can I buy that LED here?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
Does the computer turn on and work OK and it is only the Power LED that does not light up or doesn't the computer even start?
If the computer turns on and works OK but it is only the Power LED that is the problem, check that Power LED cable wires that may be in the Front Panel I/O cable are securely connected to the header pins on the motherboard.
There should be a set of Front Panel I/O header pins on the motherboard. These should include connections for the Power button, the Power LED and the HDD LED
It should be printed on the motherboard as to what the header pins are used for and how the cables are connected e.g. +ve PWR LED , +ve HDD LED and PWR for the power button
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Roberto lopez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 451
