Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación e información de desmontaje para la Surface Laptop de tercera generación de Microsoft, lanzada en octubre de 2019.
Replacing the palm rest...?
Is the base identical between the all metal and alcantara models? I would love to get the Cobalt Blue model, and then replace the alcantara palm rest with the matte black metal palm rest (seeing as it’s so easy to remove/replace). Would this be possible?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios
Hi, did you find a solution to this ? I want to do the same thing (replace my Alcantara cover with a metal one)
- de
Same. Alcantara is not resillient enough
- de
Very curious to know if this works or not.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
This question is asked on multiple different forums but none seem to have a definitive answer.
Doing some research by watching teardown video’s and photo’s will give you a good indication and then you just have to go for it.
And if it’s an easy task to replace the keyboard you can order a new one somewhere with the option to return it. You take of the keyboard and compare it with the new one. If the’re identical you can replace it. Just make sure to document it and share it for the benefit of others :).
Fue útil esta respuesta?
Puntuación 1
Anyone know the answer?
Puntuación 0
Añadir tu respuesta
Ryan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 23
Todo El Tiempo: 1,409
