Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El HTC EVO es un teléfono inteligente de HTC equipado con un procesador Snapdragon de 1 GHz y funciona con el sistema operativo Android.
Stuck on bootloader screen
stuck on bootloader screen. when I try to re-boot it just keeps coming back to boot screen
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Solución Elegida
Try a Hard Reset.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
+ I like it when you talk like that. Ever thought of running for president?
- de
Is the operating system stock Android that came with your phone?
If you installed a custom ROM, sometimes they can cause your phone to "boot loop" like that. Most of the time using a different kernel will solve the problem. That only applies if you're not using the stock operating system, though.
Puntuación 0
If you rooted the phone go into the root menu: With celll off hold down button volume tap power on while holding down. Go to recovery do a wipe cache then go to advance and do a wipe cache in your selected rooted. MOST of the time this will repair the problem.
Puntuación 0
step 1 turn off phone
step 2 count to three
step4 throw it as hard as u can at the ground
step5 pick up phone place gently in trash
step6 walk away.... lmao
Puntuación 0
Añadir tu respuesta
steve estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 4,639
