Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Dron cuadricóptero fabricado por GoPro para videografía aérea.
Main Board Chip replacement
Hello. I bought this Karma with everything for 150. However, I bought it broken. I located some broken chips. I am good and replacing chips, capacitors, resistors on boards, but I am terrible at the moment knowing what any of it means.
I supplied pictures, could you guys/gals let me know what these are and where I can buy them to reflow them onto the board???
https://ibb.co/BsFMDVp
Imagen
https://ibb.co/dDgKNSN
Imagen
https://ibb.co/bKj8J3W
Imagen
https://ibb.co/7GDbcK2
Imagen
https://ibb.co/f46wx3y
Imagen
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
you would be better off just buying another one with the pairing issue cheap. The pairing issue fix has a very high success rate. That board could have other issues that you cant see.
Fue útil esta respuesta?
Puntuación 0
Img #1 is a 15µH inductor
Img #2 is a 100µF 35V SMD electrolytic capacitor
Img #3 unable to determine if this is a bad connector or bad ribbon cable
Img #5 is a BSC0588- N-CHANNEL POWER MOSFET
Puntuación 0
Añadir tu respuesta
rookerdesigns84 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 250
