Back camera glass broken
Has anybody replaced the camera glass for the back camera, mine is cracked (still don’t know how)
Does the entire back need to come off or can the glass be replaced from the outside?
Es esta una buena pregunta?
I just fixed this by replacing the rear glass and camera lens as one piece. It was quite easy about $15 on Amazon and took about 5 minutes using a heat-gun and a plastic card. Be careful to not damage the flex that goes to the daughter board when doing so. Also only allow the card to be 1CM inside the phone when slicing the old adhesive to remove the rear glass.
Fue útil esta respuesta?
Hi @simun, thanks for your comment. Could you provide the link to that part? I would like to be sure it fits. Is it OEM?
It won’t let me link, but check MobileSentrix.
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,506
