Hi @lmorsi
You have to remove the evaporator cover panel, inside at the back of the freezer compartment to get to the evaporator fan. Access is through the front of the freezer compartment
Here’s a link that may help.
Click on the Freezer liner parts diagram. Part #11 is the panel and part #26 is the evaporator fan motor.
If the fan is not operating at all: (remember both doors need to be closed for fan to operate unless you manually operate the door switch of the open door),
Disconnect the fan from the wiring harness and use an Ohmmeter to test the fan motor winding for continuity. Don’t know what the resistance should read but usually they are in the vicinity of 25-100 Ohms and certainly not open circuit. Remember to disconnect the power from the refrigerator when using an Ohmmeter.
If the fan motor winding test OK then reconnect power to the refrigerator and test for voltage at the fan motor harness plug. If there is no voltage on the fan motor, unfortunately there is no wiring diagram but check the control board for the same coloured wires. Although if it is only a two wire fan connection then the black wire will be the neutral wire (L2 in USA parlance) AC connection and will be multipled to other AC powered components e.g. lights etc, so look for the other colour only at the control board. Use the Ohmmeter to verify that there is continuity of the wire from the control board to the fan motor plug as it may go through other connectors and not be a direct link. If the wire tests OK then check if power is on the wire at the control board.
Hopefully a start and apologies if you already know how to use a DMM (digital multimeter) to perform tests safely etc.
6 comentarios
I’m having the same problem, my question is why did it start working after giving it a spin.Does it need a simple cleaning?
- de Mike Ciula
@Mike Ciula you can try cleaning it and using a drop of oil in the bearings to see if that helps. But it sounds like the magnetic field is getting weak, and the motor needs replaced. But that is dependent upon the type of motor. If it is one with a capacitor you may just been a capacitor. But I don't know many residential units with motors big enough to use caps.
- de brandon k
I have a side by side and it’s doing the same thing this is quite a workout to pull this thing out Ang play with this fa
N this is the 2nd time it has happened
- de Jo Schwartz
@joschwartz
What is the model number of the refrigerator?
To gain access to the evaporator fan you remove the panel from the inside back wall if the freezer compartment (or refrigerator compartment if it has two evaporator units) i.e. through the door at the front.
If you mean the condenser fan then yes access is at the back on the outside, underneath of the compartments.
- de jayeff
i have a whirlpool 5 door french door refrigerator.i replaced the fridge evaporator fan motor still doesen't work could it be the control board,how ?
- de a donis
Mostrar 1 comentario más
