Saltar al contenido principal
Why are there vertical lines on my screen?
Vertical lines (mostly red, some green) suddenly appeared across my screen mid-show. They remain on any channel, any input, and after turning the TV on/off. My TV is about 12 years old but has functioned great until now. Any idea what the issue is?
Update (03/12/2020)
Hi @jayeff, it’s KDL-40V2500
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
Hi @pcal6vb ,
What is the model number of the TV?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@pcal6vb
that will depend on what those lines look like. Most common reason is a failed T-Con board followed by a bad main board and ultimately a bad panel. Post some good pictures or what your TV shows so we can see what you see. Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Hi @pcal6vb ,
Can you view the menu screens OK or are they also faulty?
If they are also faulty, since there are no error code LEDs associated with the failure, looking at the service manual the problem could be a faulty BU board, a faulty cable or cable connection between the BU board and the panel or a faulty panel.
- de
Hi @oldturkey03 oldturkey03,
I added the image above in my question.
- de
@pcal6vb dang this could be a panel error. Try a new T-con board and see if that makes a difference.
- de
I have a similar problem on a Sony TV. they are not actually vertical lines but are repeating elements associated with lighter and coloured areas on the screen. For example, on a mostly dark screen, with the input name showing you will see repeating areas above and or below the text (and lining up with individual letters or brighter/coloured parts of the image. Mine appear mostly at the bottom and creep about one third to half way up the screen (or they become dimmer such that they are not as visible as they get further from the source (test or image on screen).
I have cleaned ribbon cables, no luck so far. Thinking it is probably on the BAX board or the
Puntuación 1
2 comentarios:
Ordered a TCON Board today (Jan7/23) Will update.
- de
Did it fix your problem?
@R G Jacobs
- de
Añadir tu respuesta
Pcal6vb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 1,184
