Saltar al contenido principal
Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
Samsung 3d smpart tv model#Un55es6500f. Is there a fix?
Samsung 3d smart tv model Un55es6500f. No crack on the screen,all ports work has sound. Any one know what the problem could be and is there a diy fix for it l?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
@workforit since the bottom part of the screen still seems to be working this is most likely a panel issue. It appears as if the LCD Gate drivers have failed. Remove the back cover from your TV and take a good look at the board that connects directly to the LCD panel via some very thin ribbon cables. Those Boards are not DIY replaceable. See if you can find some obvious damaged component etc. You can always post some good pictures of your boards etc. with your QUESTION so that we can see what you see. Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Gord Stewart estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 282
