Have you run the HP diagnostic software from the BIOS? This could point out unsuspected problems in other areas such as RAM, etc.
Power on your PC, press Esc, then F2 at the prompt. Choose System Tests (Fast Test performs a 4 minute hardware check).
Unless you have severe heat problems on your system it is very unlikely, but possible of course, that your CPU/Graphics is defectuive. What temperatures are the components operating at? HW Monitor is a good app for temperature, fans, etc:
https://www.cpuid.com/softwares/hwmonito...
Before replacing your CPU try the following:
Update all drivers from HP web site, if you haven’t already done this. Chipset drivers are very important as they link all main hardware components together:
https://support.hp.com/us-en/drivers/sel...
If that doesn’t do the trick then perhaps corruption is the problem
To completely, cleanly unistall graphics drivers try something like DDU (Display Driver Uninstaller:
https://www.wagnardsoft.com/
99% of the time this has fixed the problem for me. Graphics driver can be a tough problem.
Once that is all done install the graphics drive from the HP web site.
This program is a good general driver updater:
https://www.majorgeeks.com/files/details...
There are other possible lines of investigation so let us know how it goes. I’ve only had 1 graphics card die, and that was because of carelessness on my part, and zero CPU’s die in 35 years of hardware troubleshooting.
Good luck!
6 comentarios
Hey, anyone ever tested the compatibility towards 7th gen Intel Cpus, so like some i7 7700T? Sadly the bios change log is super minimal and i cant read the stuff from there.
- de Todd Compartir
Hi @toddk80
Processor Integrated Graphics
Intel Core i7-6700T (Skylake) 2.8 GHz Quad Core Intel HD Graphics (GT2)
Intel Core i5-6400T (Skylake) 2.2 GHz Quad Core Intel HD Graphics (GT2)
Intel Core i3-6100T (Skylake) 3.2 GHz Dual Core Intel HD Graphics 530
Intel Pentium G4400T (Skylake) 2.9 GHz Dual Core Intel HD Graphics 510
- de mike Compartir
Thanks for the speedy response, even i knew above 6th gen CPUs are supported, but this wasnt my question. It was more IF a0xx series supports 7th gen, so like the Wave a1xx or a3xx series does natively. I mean all come with H170 chipset and same socket, so a question of compatibility on Bios level. HP documentation just shows the CPUs offered in their pre configured models, e.g. 6600T should work as well, even not listed.
I guess i have to simply test it somewhen
Once i get some 7500/7700t in my hands ...
Thanks again
- de Todd Compartir
Hi @toddk80
Let us know how it goes.
- de mike Compartir
@aactech will do for sure :-)
Thanks so far!
- de Todd Compartir
Mostrar 1 comentario más
