Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Chevrolet Silverado es una línea de camionetas de la marca Chevrolet fabricadas por General Motors. Mecánicamente, la GMC Sierra y la Chevrolet Silverado son idénticas.
Driver window doesn't work
My driver window doesn’t do anything. I tested the Switch and it works. tested resistance on the motor and looks good too. What else can I check to see what the problem is?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
LMR CTS  Check the wires in the rubber boots between the door and the cab of the truck.  It’s a common issues for this model to have broken wires in that area. You also need to check for voltages and see if you have power going to the motor and/or the switch. If you have power to the switch and power to the motor then you know it is the motor that does not work
Fue útil esta respuesta?
Puntuación 0
Hi,
Here’s the procedure to test the driver’s power window taken from the Fixed and movable windows section of the 2008 Chev Silverado repair manual.
The manual also has full schematics for the power windows which will help.
Imagen
(click on image to enlarge for better viewing)
Puntuación 0
Añadir tu respuesta
LMR CTS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 1,832
