Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Nikon D500 es una cámara DSLR de prosumidor lanzada en enero de 2016.
Metering Mode button not working
On my D500, the Metering Mode button isn’t working. The other 3 buttons (WB, QUAL, and Mode) are working. It has already been into the shop once (6 weeks and $150) to just be told there was nothing found and it’s working now!
A couple of times, a sharp hit to the top left corner would have the button working again, but not this time.
Since I’m in IT, I suspect it is just a cable that is loose.
Is there a teardown of the D500 that shows where all the screws are that I need to remove?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
I have opened it up myself, and reseated the connector inside the top assembly, as it was out of place. When I put it back together, it didn’t work, but a 2nd reseat worked to get it functional, not sure why.
I am going to work on making a repair guide; not sure when it will be ready.
I have created the guides of the steps that I took to resolve my issue: Cómo arreglar el modo de medición si el botón no funciona
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thinking the first attempt, I may not have seated the tiny cable just right, and had to do it again. I am at 6 months, and it has not had any sort of failure of the button.
- de
Añadir tu respuesta
Wolphin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 499
