Saltar al contenido principal
Modelo A1278 /Procesador 2.4 o 2.66 GHz Core 2 Duo de mediados de 2010
Preguntas 795 Ver todo
No Bluetooth, WiFi, or Camera!
I don’t believe it detects any of the three unfortunately.
Initially thought it was just WiFi and Bluetooth (Airport card) issue, however I’ve noticed that the iSight camera is not detected as well, which leads me to believe the cable is the issue, I’m not a pro however. I tried plugging in the cable multiple times (slightly different angles) but no bueno.
  • I received the laptop like this, always had these issues
  • Prior to my attempt we took it to best buy, included below, best buy quoted something ridiculous from what I remember, 350+
  • This system doesn’t seem to be able to boot into hardware test
Was hoping for some insight. I’ve included some pics. Thanks in advance!
Es esta una buena pregunta?
Puntuación 0
1 comentario
Is this the original display? I wonder if someone replaced it.
Do you know the systems history? Can you give us any more details on what happened before the problems where seen.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
You can try replacing the display assembly. If you don’t care much for the looks of it, even iFixit has a couple of pretty cheap C-grade display assemblies for sale. Replacement is quite straightforward, only torx and philips screwdrivers are needed. If that wouldn’t solve the issues you’d have a faulty connector on the board, but you should be able to verify its conditions before purchase. Here’s the needed part:
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Display Assembly
Imagen de MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Display Assembly
Producto
$249.99
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
Let’s try this run the onboard diagnostics, restart your system and press the D key hopefully diagnostics will run on your system, Apple messed up a firmware update and some systems diagnostics is not working.
Take note of any error messages and codes and let us know.
Reference: Mac startup key combinations
Puntuación 1
1 comentario:
I forgot to mention, lol yeah diagnostics doesn't seem to work on this system. tried many times. I don't have much history of the laptop to be honest, it was a gift from someone and has just been sitting in storage for a while. Before my attempt to repair we took it to best buy and im just remembering they left some notes as well, which ive included to original post
- de
Añadir tu respuesta
joseph estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 103
