Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Smartphone insignia de Huawei lanzado en abril de 2018. Modelo CLT-L29.
My P20 Pro only has service when plugged into a charger.
I took my phone to a repair shop as i completely smashed my screen.
He managed to replace the screen but now my phone will only connect to Vodafone network when plugged into a charger.
If i remove the usb from the charging port it goes to no service
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Sounds like the battery may have gotten disconnected and/or died.
Reemplazo de la batería del Huawei P20 Pro
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
Changed the battery and still the same issue. Replaced the Antenna as well. Any other suggestions?
- de
@jayb_1991
I'm facing the same issue after replacing my battery's
were you able to solve your issue ?
- de
Hi, same problem for me. After battery replacement, signal is ok only under charging or if I connect hear jack. Any suggest?
- de
Añadir tu respuesta
jayb_1991 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 788
