Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Fridge stops cooling every couple days
My Whirlpool has for the past couple weeks has randomly stopped cooling. I unplug it let it sit for a couple minutes and plug it back in and everything is fine. But a couple days later we’ll have a pool of water on the floor from melting ice tray. I’ve read through other guides but none of them mention intermittent non cooling issues. Due to lack of time the past couple of weeks I’ve been putting it off by unplugging it and plugging it back in. But it’s time to face the facts and make time to fix it. Where do I start? To be clear both the fridge and freezer stop cooling entirely no air what so ever, not even warm and no compressor noise.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
14 comentarios
Hi,
What is the model number of the fridge?
Sounds as though it is not auto defrosting and then not restarting at the end of the auto defrost if you can't hear the compressor running.
You may have to monitor the fridge for a while to work out what is (or is not) happening, as I don't know how to manually start an auto defrost sequence. Maybe the service manual will show this.
Once the compressor is running check that when it has stopped running that it restarts after about 20-30 minutes. This is about the usual time allowed for auto defrost. Be aware that it also may stop running simply because the correct temps have been reached in the fridge/freezer but should startup again if you leave a door open for a few minutes.
Auto defrost usually occurs once every 8-12 hours so the compressor should be stopped at least 2-3 times per day.
If it doesn't restart after the defrost time period has elapsed at least you have a starting point.
If it is not defrosting it could be a faulty defrost heater. This could ice up the evap fan after a few days and prevent cold air being blown into the fridge but usually the freezer temp is about right if this happens.
- de
Model number is WSF26C2EXF01
I have been trying to catch it when it shuts off but I often don’t find it until there’s a pool of water on the ground. I also attempted to locate the owners manual but could only find a one pager for installation on whirlpools website. If you could find a full manual that would be fantastic. The next time I catch it off I’ll wait for 20-30 minutes and see if it tries to kick on. @jayeff
- de
Whirlpool side by side stopped running pool of water in the floor after unplug for couple of days and repluged it started back freezing and cooling but stop running again after 2 days but will restart again if left unplug
- de
Need help finding the problem
- de
Hi Cameron,
did you resolve this issue? I have the same issue with my Whirlpool fridge.
- de
Mostrar 9 comentarios más
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hi,
Here’s the most common problem parts for the symptoms you’re describing, taken from this website
The supplier was only shown as an example to give an idea of the cost of the parts most likely to be the problem.
There are other suppliers that may suit you better if you go to order parts.
Just search for WSF26C2EXF01 parts to get results.
Also found this link to the service manual if you wish to purchase it. I don’t know what it contains but wiring diagrams and tech sheets are usually very helpful
Fue útil esta respuesta?
Puntuación 2
Hi @Clyde freeman,
What is the model number of the refrigerator?
From the description is seems like there is an ice build up that may be stopping the evaporator fan from operating to cool down the refrigerator.
This could be caused by a faulty defrost heater or a blocked ice meltwater drain from the freezer to the evap pan under the fridge or if the fridge doesn’t go into the auto defrost cycle (at least once every 8-12 hours - depends on maker) then perhaps the defrost thermostat or the control board (depends on model)
You should be able to hear the evap fan operating. It will run as long as the compressor is running and the doors (both doors) are shut. When a door is opened the fan will stop. It is located near the evap unit which is usually located behind a panel, at the back inside the freezer compartment. Do not confuse this fan with the condenser fan (if the fridge has one) which is outside the compartments near the compressor and can run whether the doors are open or not.
The fan will not run when the doors are open or if the fridge is in the auto defrost cycle. the cycle lasts for about 15-25 minutes and then the fan and the compressor should start again to cool the freezer/fridge back down again
Puntuación 0
Some fridges use a small heating tube (glass with filament inside that heats up). It if stops working to defrost the freezer area, it builds up with ice. This will lead to the puddles of water as the ice melts when you unplug the fridge.
Puntuación 0
Añadir tu respuesta
Cameron Barker estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 42
Ultimos 30 días: 162
Todo El Tiempo: 39,067
