Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El teléfono insignia de Samsung con stylus y el sucesor del Note8, lanzado en agosto de 2018. Cuenta con una pantalla de 6.4 "y hasta 512 GB de almacenamiento a bordo.
Wrong file TWRP bootloop
Hi,
After install TWRP from Odin my Note 9 was stay on bootlop 'Samsung Logo' and restarting, i can't go to Download Mode and Recovery but phone only restarting bootloop.
It happend after install wrong twrp files (\twrp-3.3.1-1-star2qltechn.img.tar) i have select on Odin "Rebooting"
What's going now? Regards Thank you for help
Recovery and Download doesn't work, i can't going to him.... only restarting *****
video: https://streamable.com/k242c
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Hi Eda Ea, did you able to fix the problem , I faced the same one
- de
Hi eda ea
i have the same problem
were you able yo fix your phone?
if yes, could you please tell us how?
thank you
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Turn it off full power off take cable out hold volume and Bixby whilst holding plug in USB
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
After a failed attempt to remove the battery and ending up cracking the back glass, what you said was the solution. Just ONLY hold volume up and bixby, then plug in the USB. Thank you very much!
- de
i cain't turn off my phone it just go off and on on logo after it's off i plug it in and it starts again. holding buttons doesnt help
- de
Hi Eda ea !
There is always a risk when ROOT a smartphone.
Did you try the recovery mode with the following commands :
Volume Up + Bixby + Power key together for a few moments
Imagen
Puntuación 0
4 comentarios:
I waiting for battery runs out of charge.  And push Volume UP + Bixby + Connect Cable USB, was starting to Samsung logo and bootloop…. i installed TWRP from other model (A6+) my misstake… and have select option in odin Nand Erase and Auto Rebooting…
- de
Indeed, if the wrong TWRP model has been installed.
A reset factory will have to be done.
I suggest you consult this link: https://www.hardreset.info/devices/samsu...
- de
Not possible it’s same problem….
- de
If even this procedure does not work, I am afraid there is no other solution, unfortunately. Maybe another member will have a second solution.
Good luck with that!
- de
please help me i have the same problem
Puntuación 0
Añadir tu respuesta
eda ea estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 1,451
