Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La TI-89 Titanium es una calculadora gráfica desarrollada por Texas Instruments (TI) y lanzada en 2004. Las calculadoras TI-89 incluyen un sistema de álgebra computacional que permite la manipulación simbólica de expresiones algebraicas.
missing horizontal pixels on display screen
I have two missing horizontal lines of pixels. The first is just below the tool bar and the second is almost half way down the screen. I ran the self test for the calculator and confirmed that the lines were missing. Is this a hardware problem or software problem. How can I determine which it is. If it is a software problem will a reset fix it without removing the factory installed programs. But if it is a hardware problem would this be an easy fix.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi this sounds like a hardware problem. Unfortunately, unlike the TI 83 and TI 84 lineup, the TI 89 ti doesn’t have a standard ribbon cable you can fix, instead TI attached everything to one piece making it nearly impossible to fix yourself. Even the most skilled calculator enthusiasts I know haven’t been able to repair a TI 89 ti display. :(
I’m sorry I wasn’t able to help you repair it, however if you have any other questions I’ll be happy to answer them.
Fue útil esta respuesta?
Puntuación 1
https://www.cemetech.net/forum/viewtopic...
Puntuación 0
Añadir tu respuesta
Lawrence Dunbar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 1,943
