no green light on charging cable
macbook pro does not power up/turn on . No green light on charging cable
Es esta una buena pregunta?
If that’s the case I would start off by inspecting the systems MagSafe connector making sure its clean and the metal contacts are not burnt.
Here is the replacement MacBook Pro Unibody 13" and 15" MagSafe DC-In Board and here’s the guide to replace it Reemplazo de la placa de entrada de CC del MacBook Pro 13" Unibody Mid 2010
Given the age of the system you may also need a new battery MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery and here’s the guide to put it in Reemplazo de batería de MacBook Pro 13" Unibody Mediados de 2010
Producto
$9.99
Producto
$69.99
Guía
Dificultad:
Fácil
10 minutes
Guía
Dificultad:
Difícil
45 minutes
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 40
Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure the cable and the connector are in good shape and you have the correct charger as well for your system. Do make sure its a real Apple chargers as there are many fakes out there! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Real vs Fake Magsafe 2 Charger Macbook Pro
- de Dan
the charging cable works on other macs, not on this one
- de Greg E Terres
