Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El SanDisk Cruzer Glide es una unidad flash USB con un conector USB retráctil. Viene en una variedad de capacidades de almacenamiento con una caja de plástico negra y roja para todos los modelos.
Is this Flash Drive fixable?
I accidentally droped the laptop that this was plugged in to… the cover for it split and when we went to plug it back in, it wasn’t showing up on the computer. I feel like this can be fixed easily since the connection to the motherboard is still intact… It’s just not showing up on the laptop.
Imagen
Imagen
Imagen
Imagen
Es esta una buena pregunta?
Puntuación 0
1 comentario
It probably cant be fixed unless you go to a professional so unless you have information you need on it then give up. Or if your lucky you can play around with it and it will work. Good luck
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I agree that it probably can be fixed but easily…no. It’s hard to say from the pictures but when a USB drive is physically damaged, it usually means some traces on the circuit board are damaged. This can be fixed but it requires micro-soldering and that makes any DIY repair unlikely.
Here’s an example of the type of damage I am referring to.
Imagen
If you value the data on the drive, you could send your USB Drive to a micro-soldering repair specialist.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Brett W estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 37
Todo El Tiempo: 940
