Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Acer Extensa 4630z es una computadora portátil presentada por Acer en 2008. La serie Acer Extensa es una línea de computadoras portátiles Acer diseñadas para usuarios comerciales y de oficina.
Why is the display not working after I reinstalled the RAM?
I removed and reinstalled the RAM and HDD and powered my laptop and it ceases to display anything. As a matter of fact it was working properly before but was crashing during Windows Xp loading with BSOD, Now the laptop powers on but no display whatsoever.
Es esta una buena pregunta?
Puntuación 1
2 comentarios
@huracanevo are there multiple memory module installed?
test with one stick at a time
- de
I only have single RAM but two DIMM
slots
- de
Agregar un comentario
2 Respuestas
Solución Elegida
It is seem to be only some boot hardware failure. Do you get any system beep sound when you power on laptop. Do one thing. Only install RAM in same slot where it was working before. Do not install HDD. Now power on laptop. Also inform any LED on display turn on or now.
I think ram is not properly installed or hdd is not properly fixed. Inform us what is system sound or beep sound when turn on.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
There are no beeping hardware internally installed .... there are LEDs indicating HDD ........ I will give it a try
- de
Display should work no matter HDD is installed or not ,right Its just the RAM that display is affected
- de
Did it and no sign of display working..........But the first time I press power button it powers up ...shuts down for a while and then powers up again......What is the cause?
- de
Respuesta Más Útil
The ram may not be seated in fully or dust is inside the ram slot. Make sure they are seated in well.
Puntuación 1
3 comentarios:
No I did it multiple times but the results are same
- de
Hi @huracanevo ,
You didn't leave the battery in when you removed / replaced the RAM and HDD did you?
Try a power reset,
remove battery (and charger if inserted) press and hold Power button for 20-30 seconds then release.
Insert charger and switch on charger (leave battery out)
Assuming RAM at least is installed, turn on laptop and check if display works.
- de
I actually went through Youtube videos that said static could be the cause of display not working......I did that multiple times as well ...no luck
- de
Añadir tu respuesta
Namaste Holiday estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 765
