What can I do to replace a circulating pump in goplus inflatable spa?
I used my spa three months and the circulating pump died. I have searched everywhere to find a replacement. I’ve emptied n refilled the hot tub. It heats but the warm water isn’t moving around like it is supposed to. It’s not inflated now as there’s snow outside but I really would love to fixit before Spring.
Update (02/10/2019)
It is still in warranty period but I am responsible for so many costs that I just can’t do it. It would cost almost as much as buying it again. However here is the information. The spa is a GoPlus model PH50017 / PH50018. 110V - 60Hz 1500W. Jet 600W/0.81HP. Heater 900W/1.22HP. I am willing to take it all apart n even if replacement won’t fit would buy an external pump n hose it in. If this even a thing. I’m pretty clueless but very mechanical . Thank you!!
Es esta una buena pregunta?
2 comentarios
I had same problem. Took shop vac on blower setting and blew through the pump. Must’ve had a small clog as it cleared out and started flowing properly again. Unfortunately the heating element burned up and mine was only 3 weeks old! Like you said it’s not worth the work to return. Purchasing a saluspa instead as the pump is external and easier to replace if need be. Good luck
- de Carl Mutschler IV
How do I access the pump inside the go plus
? There is a leak inside of it at the motor. Can’t get inside to reconnect hose, or whatever came undone? Can’t see in there either? Just need to know how to get to it! PLEASE!!
- de Michelle Davila
