Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Kodak EasyShare C913 es una cámara digital de 9.2 MP.
What does .AF mean?
When you push down the flash, it goes off but than it goes off AGAIN and the picture turns out as just a white blob. Why does the flash go off the second time?
Es esta una buena pregunta?
Puntuación -1
2 comentarios
Laura Gross, just as a follow up, I was wondering if you got your camera working again.
- de
Midway Island.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Not sure about the .AF. It would depend where it shows up on your camera. I do believe that it shows that your Auto Flash is on. The double flash is done by your setup. For Red-eye The flash fires twice—once, then again when the picture is taken. So you should check your manual, available here,and see how to turn it off. I hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Laura Gross estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 907
