Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El HTC HD2 es un teléfono inteligente fabricado por HTC y que ejecuta el sistema operativo Windows Mobile 6.5.
phone lock remove help
htc hd 2 phone lock can not open phone if i place the phone lock on i can not get in to the phone does open how can i get past the lock to remove it were ca i find the drivers to repair or reinstall the phone
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
donald watson you can try and perform a factory reset using phone buttons. You can still perform a factory reset by using buttons on the phone even If you can't turn your phone oo or access the phone settings.
1 With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
2 While holding the volume buttons, press the END/POWER button briefly and then release it.
3 When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
4 Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Now I am not sure what will happen with your information when you perform this. It is possible that you might lose all of it, so please use it knowing that this may happen.''italic text'' A hard reset usually does it....Good Luck
Fue útil esta respuesta?
Puntuación 2
my cell htc hd2 is locked ...
i entered more than 5-6 time wrong password so phone is lock & 1 error shown on screen like
several incorrect password have been entered to continue entry enter a1b2c3 in case of emergency enter an emergency phone number
so what i will do ...
plz sugest me..
Puntuación 0
i have a problem my htc just recive calls i cant make calls ..can any one help
Puntuación 0
Añadir tu respuesta
donald watson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 2,405
